lancer GLX alarm
kahheng
86
KL/ Johor
shitty problem,and its bugging me. alarm keep triggering and it seems to have some errors coding. its kinda freaking me if i wana take it back to EON..currently im not using alarm to lock the car.just manual. coz if i use alarm to lock, there is no beeping,and after a while it will self trigger. tried to press the LED panel few times according to the manual but fail. somebody pls help!! :(
kampoon
1,205
89
1,648
haha....for me .....just unplug the alarm harness and install a new one ......he he
kahheng
86
KL/ Johor
batery is new..alarm still ok but sometimes this prob will come back and haunt me...haih
PabloIceman
3,083
291
1,683
Is it a 2-way alarm? If so, check the transponder/transmitter. Mine 'kaput' then also have similar symptoms like yours ... the transpnder spoilt due to age and car being parked in the sun ...
kampoon
1,205
89
1,648
Stock...one for GLX is just a upgraded Ctr locking + basic alarm + basic immo (just to de-activate starter when alarm trigger)
PabloIceman
3,083
291
1,683
I see ... so there should still be a receiver antenna probably installed under the steering wheel column ... need to go to car alarm shop to test then ..
kahheng
86
KL/ Johor
iceman, wat do u mean by transponder? do u mean the LED panel on the steering? the round black one? fyi transponder is only availble in 4wd ie triton
PabloIceman
3,083
291
1,683
It should normally be installed under your steering column .. have to remove the cover to get to it .. but i suggest u get some1 who knows where to look for it and check if there's a problem. U can't see any physical defects on it, normally ..
kampoon
1,205
89
1,648
i know.....if you want to know as well......I am willing to share......
I guess...Wonderkid knows also ???
kahheng
86
KL/ Johor
can show me the location of the thing? a bit difficult to get techincal support at EON coz lancer alarm is directly from japan whereby triton is by local (COBRA alarm)
kampoon
1,205
89
1,648
can can ...but how ??? u wanna to call me ???
andychua
116
Sabah
Where is thr alarm location in our Lancer ?? I do not know .... Now mt alarm do not have Beep when I unlock n Lock the car ... =.=" dono what happen ... It just happen this weeks ...
Hi guys, just wanna wasting time around to view post of you guys engine build.
Chassis: EG9
Engine: B20Vtec with B16A heads
Chip: Hondata s300
Top part
Aerospeed Adjustable cam pulley.
AEM fuel regulator.
Skunk2 Intake Manifold
S90 TB.
HKS air intake (Local, No CAI)
B16B Type-R, valve spring retainer.
Bottom End
Stock conrod, shaft, piston (Balanced)
4-1 Mugen replica header.
Dynoed: Not yet.. last time dyno blown on 220hp
