Lamborghini Diablo (made 1991)
Mugenz
73
Hi there,
My brother-in-law is letting go his diablo, the spec as below..
pls PM me for contact number, price and more details on the car..
no joker comment and funny question will be replied..
introducer are welcomed and commission will be given.
btw, the plate no. will not sold together.
Cheer!
Engine
Type : Sixty-degree V12
Construction: Light alloy block and heads
Valve gear: Four valves per cylinder operated by four chain-driven overhead camshafts
Bore and stroke: 3.43in x 3.15in
Displacement: 5729CC
Compression ratio: 10.0:1
Maximum power: 492bhp at 7000rpm
Maximum torque: 428lb-ft at 5200rpm
Transmission: Five speed manual
Body/Chassis
Steel square-tube spaceframe chassis with two-door,
two-seat coupe body in alloy, steel and carbon fiber.
RUNNING GEAR
Steering: Rack and pinion.
Fronst suspension: Double wishbones with coil springs, telescopit shocks and anti-roll bar.
Rear suspension: Double wishbones with twin coaxial spring shock units per side, and anti-roll bar.
Brakes: Brembo Vented disc, 13in. diameter (front), 11.2in diameter (rear)
Wheel: Multi-piece alloy, 8.5in x 17in (front), 13in x 17in (rear)
Tires: Pirelli P Zero 245/40 ZR17 (front), 335/35 ZR17(rear)
Dimension
Length :175.6in
Width:80.3in
Height :43.5in
Wheelbase:104.3in
Reason for selling: upgrading..
zique
Kopi O Lesen Driver
678
Kuala Lumpur, M
mikeyip.com
Nice stuff, do you have a pic of the front of the car?
Will spread the word for you.
boggysv
2,025
4
u can try to make an ad in sinkapore....i believe easier to get buyer there
NoTiGuY
old school
1,497
7
5,138
PG-PJ-KL-DUBAI
www.cardomain.com
Guess this was the car customs had it with them for 5 years and Bob Wong (808) bought it off and sold it out. Will try to spread the words here.
ps:- the road tax is under 4ltr instead of the actualy 5.7ltr?
Hi guys, mind to share with me how much the FICD will help on turbo engine + air-cond and how to install this thing..
Hope those sifu here mind to share their knowledge on this thing. :adore::adore::adore:
Thanks.
