l5 auto wiring or engine problem?
yakusza
19
Putrajaya
my Symptoms:
1.electronic device going crazy(RPM meter,temp meter,radio player,headlight) when gear is at Reverse.
2.when cruising,Symptoms 1 happen if acc pedal realease but all went normal if acc pedal is step on.
3.i perform DIM(do it myself) check,i touch a metal to car engine,there will be a spark..WTH..??
now my engine wont start at all..
any pointer,suggestion,diagnosis muchly appreciated. :adore:
xtremeleo
3,247
464
5,183
wth indeed sir, sounds like wiring problem. what had been done prior to dis problems?
yakusza
19
Putrajaya
the last electronic device i installed was Power amp..but it was 1 year ago..
if it wiring prob,care to share where should i check first..?
i'm looking into a mod........will the daihatsu L2 piston fit into a L5 engine? if it can be fitted , will i need to mod anything ? thx :banghead:
