yewly1990
So yewly1990's problem fix already? Or the engine exploded due to insufficient fueling with full boost in closed loop.
My problem fixed, a/f ratio too lean, and ignition timing not correct by previous tuner.
Which tuner now?
And Previous tuner charge every time you go back.......
Puchong RS dyno
---------- Post added at 06:53 PM ---------- 6 hour anti-bump limit - Previous post was at 06:53 PM ----------
Nowdays most tuner are good businessman
I tuned my swift BOT at RS too, robyn. I ask him and he said he pulled timing and add more fuel trim at higher boost/rpm/load for safety.That might explain why your knock gone when timing is pulled. I'm using bigger injector oppose to yours 1 extra injector.btw
Similar threads | |
