idling too high
xinghonh
1,415
7
hi bro
im having this prob where my idling is at 1.5k rpm
i tried adjusting the throttle body by screwing tight to the max
and yet the problem still cant be solved
plz help me~!!
allance
337
8
when u got this problem frist? ok! ....i think myb ur vacum hose is leak! pls checking
nezumi
21
40150
daiichi-ketsui.com
could be broken tps...
i had d same prob... changed afm, changed aac, changed ecu... nada! still idled high...
yup, it was d bloody tps... when i pulled the tps socket towards me, the idle dropped to normal...
temporary, i used a 15mm bolt & put it in between the tps socket and the intake pipe connecting hose dat leads to the throttle body... well, it's ok now ;-)
dunno 'bout u, mine is d rb20det...
hope this helps...
xinghonh
1,415
7
haha correct...its 4g93 bot
i heard sumthin bout tps where they can use a machine to reset it?
nezumi
21
40150
daiichi-ketsui.com
i'm not familiar wif d 4gxx series engines...
on rb engines, all u need is a digital multimeter... and set the tps within d specified range, which is between 0.45-0.50 volts... a very-very simple job...
should be similar to setting the tps on other cars... correct me if i'm wrong...
Fellow readers, I am glad that you have followed me this far up to the 15th week in the Project Z restoration, modification and build. As certain readers have pointed out that they are gladly to donate the money to make this project a reality, I have seek permission from Tom and he has approved a donation box through either Paypal or Maybank.
The donations can be...
