How to DIY install a CD player for CAR?
yzliew
114
The wire?
Front Left,Right Speaker knw already
Rear Left ,Right Speaker also know already.
Radio Anthena beside with a extra wire is for what??
And Yellow,Black,BLue mix Yellow dont know is what?
How bro got any website teaching?
help here
PAUL_CJ
275
PUCHONG
Radio Anthena beside with a extra wire, i think its remote antena which for motorize antena (can also conect to amp)
And Yellow (connect to ignition key) black(connect to ground -), blue mix yellow is memory (connnect to battery +)
(i guess.........)
yzliew
114
what you mean for ignition key,connect to cd player one?
yzliew
114
fren i got connect green to power,black to ground with correct test already.
but incase i cannot find the iginition wire,dont know is break or going to where,so where the iginition wire from i plan to put another wire to replace it or find it out?
yzliew
114
paul let help me again.
i install already all thing is ok and good only one thing is
after i switch off my car then start back the cd from player auto come out and all thing that i set in the player like volume equalizer and radio channel all is reset
WHY???
what wire that i put is wrong???
got one is TEL MUTE i did't plug,and all 4 channel speaker 8 WIRE i also did't plug i only use the pre out RCA.
is that the problem cause i did't plug any speaker wire?
or other thing help bro.
Urgent
Thanks
PAUL_CJ
275
PUCHONG
i think i hv terbalik yellow n blue mix yellow. one of it should be memory which connect to battery n another 1 connect to key. sorry, hehe...........did u refered back to user manual?
yzliew
114
bro mean i terbalik the iginition and the power already??
yzliew
114
fix already thanks bro.
Haha my mistake...T.T
You is ICe intaller??
yzliew
114
i see
I am still learning
Any idea my car door panel is 5.25 wan change to 6.5"
How??
plan take to shop but if can DIY better.
i put
HU one pre out
(using Y changer to change one pre out to two pre out )
>to two amplifier
>one amplifer for 12" woofer
>one amplifier plan to get a SoundStream XSC6 6.5" one to replace the panel that i said.
Any idea??
and wan ask the power cable direct from battery into amplifier i only place a 1 to two 30A x2 enough already??
