HELP: Where to find CT9A roofing lining?
ongteckweng
5,000 RPM
5,806
55
yesterday on the way to Ipoh, my right roof lining (connecting front windscreen to roof n all the way to the rear windscreen) flew away while doing some high speed cruising...saw that bugger flown n unable to stop n retrieve it as there were a 335i chasing my ass. anyone has any idea where i can get the replacement with new clips? thanks in advance...
edit: Its call "Drip Moulding"
pangyau
1,153
302
1,683
Malaysia
Hi Ong,
how fast you go until the rubber flew... must be more then 200kmh???
what's the max speed you logged?
you may use this link to find the item you need... just a suggestion...(link given by pabloman)
AutoCenter.net
Mugenz
73
yeah..anyone can lead to the source..im looking for one too..
pangyau
1,153
302
1,683
Malaysia
hi Mugenz,
you might try the Mitsubishi Centre in Malaysia...(direct call and request to spare parts department)
provide them the correct part number or correct name...
it might take minimum 60 days if the part have to order from Japan. (Quoted by them).
Mugenz
73
thanks pangyau. Any idea what's the correct name and part no. for roof lining? haha :stupid:
bro ongteckweng, u got the batu caves contact no. from kenzo? can u plzz pm me?
thanks..
pangyau
1,153
302
1,683
Malaysia
Its call "Drip Moulding" (quoted by ong)
you may use the link given to search correct name and part number i don't know la...sorry.
you may call the center and ask them about it. the spare parts department will help you out.
since i also new into this CT9A parts.... kinda hard to find parts compare to my previous car (local product).
might be you can contact other sifu to help you out...
teek
159
30
hi ,
i changed the roof moulding b4 . it cost me RM400++ each , and the clip is same with wira / waja. will try to find out the part number for you.....!
Evolution_tme
128
44
i lost 3 or my "roof linings during speeding on the highway"
each cost me 450 bucks..
i got fed-up and the fourth one i glue it using the windscreen glue....clip itself is not enough to prevent it from flying..after glue-ing it...no more problem whatsoever passing 200km/h
anyway...u can order the parts from ur nearest sparepart shop. I order mine in ss19/6 sparepart shop. slightly more expensive
the best way since u using evo 7,8 and 9 u can go to PROTON "EON" service center in glenmarie....(not avalaible for evo 6 and below)...they have original mitsubishi parts there...and if iam not mistaken for evo 7 above they are only selling for around RM 280 each.
teek
159
30
u mean the black glue for windscreen? ic... next time should try it.
ongteckweng
5,000 RPM
5,806
55
evo tme...good advice...the only downside will b all the clips will b broken if u r going to change ur windscreen but since the clips r much much more cheaper than the drip moulding, i guess its a good way to keep them intact. will try EON Glenmarie next week. its possible they hv them since Evo 9 was sold locally by MMM
Guys,
I just bought an adjustable coilovers for my car and plan to install it soon. Its a soft/hard/high/low kit. I have searched, googled & asked around some friends for tips & advice but none of them can give a very clear & the same answers. I found out there are many factors that need to be considered rather than simply installing it.
The most common issue when i was browsing the web is the PRELOAD setting. From my understanding, PRELOAD means when your coilover height is adjusted...
