Help needed: Cylinder Head for Coupe
BlackSamurai
9,000 RPM
9,656
24
near 7-11
www.hcc.ne1.net
One of our Tiburon owner, Sandra, her Coupe have problem, her mech told her that the Cylinder head is spoiled, The mech quote her RM2K plus for the cylinder head (not sure is it just overhaul work).
I'm not sure about the damage of the cylinder, anyone have resource (contact for spare parts/ mech) on this? Sandra need it.
Hope that you guys can post it here.
scoupe
1,087
37
5,148
shah alam
hyundai spare parts warehouse 55690888(new parts)
Li Meng auto parts(used). ah meng 012-3870118
ah kent 0123760118
if not mistaken Li Meng got coupe half cut so he should sell the stuff u looknig for
BlackSamurai
9,000 RPM
9,656
24
near 7-11
www.hcc.ne1.net
thanks for the info, nicholas, will pass the contact to her.
Daniel Lee
2,950
4
My mechanic said to change the engine will cost RM3k plus. Better solution than to repair the cylinder head.
My regular mechanic had been changing engines for Toyotas and also Hondas. He had been handling my Coupe and another dark blue Coupe problems all this while.
You can contact him at 019-3171370 (Ah Soon).
Ace
715
Penang
Daniel,
just curious. How much does your mechanic charge to one is to swap in a 4G93T into a coupe?
Daniel Lee
2,950
4
Ace, I've enquire from my mechanic about transplaning the 4G93T engine to Coupe. He advice us not to do so because it will cause lots of problem and we must also deal with JPJ officers not knowing whether can pass or not. The engine itself will also give more problems compare to our beta engine. There are lots of 4G93T in the market now. It comes with single cam and also twin cams. Mainly for Wiras but not suitable for Coupes.
As additional, I enquire from my mechanic about transplaning a 4G63T engine into Coupe's bay. He said that the transplant will cost about RM6-7k. This engine availabity in the market is poor compare to 4G93T.
As a mechanic's point of view, he advised that Coupes stick to their original Beta engine is the best.
~Hope I answer your question~:regular_smile:
dartango
204
May I know what are the symptoms that shows a requirement for cylinder head replacement and how to protect and avoid such problems?
Also would like to know the interval for changing the timing belt for coupe RD2? I normally send my coupe to authorized Hyundai Repair Center. I hope they will do a routine check.
Thanks.
Ace
715
Penang
even if you didn't hit 70K. you should visually inspect the belt for any crack or torn side. Mine did and I change it immediately.
:_:
Ace
715
Penang
usually when you change. mechanic will advise you to change all belts together and also the bearing since it involve take many parts before your belt can be change.
The Marketplace Top Posts
Unfortunately for me, I somehow corrupted some of my photos and need to retake the brake bleeding process so that'll be done in part #3 of the 'how to improve braking performance' series.
But for now I'd like to discuss this particular modification that I had done - Steel Braided Hoses.
The original OEM brake hose is made of a special rubber compound that's able to withstand the 1000psi (probably less...
