Help! HICAS Boss - Part Number?
RERider
2,756
104
3,163
Putrajaya
My 4 wheel steering (HICAS) is not functioning due to broken wires in the Boss kit (between the steering wheel and dashboard). I tried to fix it but failed. :sad_smile:
Also my horn and the +/- shift level knob are not working at all. HICAS and Airbag warning light comes ON.
Is this thing called HICAS Boss kit? and I do need the part number very urgent. Anyone could help very appreciate.
Oh yea it is for R34 GTT (M-ATx) facelift model (08/2000).
Million Thanks in advance.
RERider
2,756
104
3,163
Putrajaya
Anyone here got nissan OEM part number catalogue? or any web links???
V-Spec
1,861
170
5,163
RERider, NISMO made a HICAS Boss kit (Part No. 48416-RS020) but will not be useable if yours is a M-ATx transmission.
RERider
2,756
104
3,163
Putrajaya
V-Spec- Bro, many thanks for the info.
Is it safe to drive the vehicle? What I feel is the steering now is a little bit hard. Are those wheels back to normal position? :confused_smile: Worry abt safety if those wheels out of range...
eyong
4,083
53
1,648
This is a good question.
With aftermarket steering like Momo etc, most installers would use HKB boss-kit (coz Momo does not make for Skylines). Would that have an effect, or a different boss kit for Skylines with HICAS (and airbag)? What are your thoughts, or recommendation?
Appreciate in advance.
V-Spec
1,861
170
5,163
RERider, have you checked your Power Steering Fluid Level? Low levels will light up the HICAS warning light too.
If all else fails, get a Tomei Lock kit. :_:
eyong
4,083
53
1,648
Plus there is some sort of HICAS sensor at the bottom column ... You may want to clean that out too ... :shades_smile:
RERider
2,756
104
3,163
Putrajaya
V-Spec- I did checked the PS fluid level. It is fine. Will check the sensor next. Cheers bro.
eyong- U still can use an aftermarket boss kit, but make sure u attach with the original HICAS boss too. Ur HICAS light will come ON after 5 mins of driving if u didnt do so.
eyong
4,083
53
1,648
Thanks RERider ... So I understand that the aftermarket boss kit has no specific wiring onto the HICAS unit/wiring.
Appreciate your help very much ...
RERider
2,756
104
3,163
Putrajaya
There was a broken wiring harness (very thin & flat) inside the HICAS Boss when I took out. It is impossible to fix it back.
I dont know whether I'm running on a 2 wheel steer now or 4 wheel steer since I took out the whole HICAS boss kit. The HICAS light comes ON after 5 mins of ignition or after driving a long straight road. Does it safe running it without the HICAS boss kit?
Anyone could help me to find the part number? anyone know is there any chopshops selling R34's halfcut?
RERider
2,756
104
3,163
Putrajaya
Pic
The pic shown the HICAS Boss kit that I've been looking for. The one on left is the Tiptronic type and the right one is Manual type. The difference between manual and tiptronic are the socket (red circle). I need to know the OEM part number for tiptronic ASAP. Anyone?
RERider
2,756
104
3,163
Putrajaya
e-yong- Thanks for ur free bump.
ANyone?
RERider
2,756
104
3,163
Putrajaya
Dino- any news from SG?
Tom - any luck?
Cheersm8.
i just got condenser replacement for my car.
but the inlet/outlet has not been covered when stored.
so theres some rust/oxidation like at the inlet/outlet, maybe the inner core also.
any suggestion how to clean it?
petrol? carb cleaner?
other chemicals?
