HELP! gasket burn and potong head? anybody can explain?
vin9277
33
Jitra / Kedah
hey anyone out there can help me out here.. my mechanic said tht my engine heated up and because the engine was on whn radiator was dry so my gasket burnt and probably caused my 'head' to bend. does this refer to piston head? or cylinder head? and he says tht they need cut the head to even it out again. is this a good thing? any negative impact? and can anyone tell a rough estimate how much it should cost to replace gasket and cut the head? :confused:
kenzo
6,000 RPM
heya bro, no problem with skimming, im pretty sure he meant by skimming ur head, its ok no problem with it, just make sure its been done by some1 professional, and its better to get slightly thicker head gasket, not sure about the cost bro, wat car ur driving? and cost depends on the workshop and machine shop u go to
kian27
62
5
1,508
bro is cylinder head...normally no hav any negative impact,usually it nit to done by every gasket burned car...if change gasket only & skimming it wont cost much i think mayb <rm500+/- nt sure bout it..but same as kenzo say stil depends on the workshop..
Garrett
48
4
1,508
bro, never heard these wshops before......just dont simply go any Ahseng or Ahwai shop. Might spoil yr engine.
Similar threads   Forum
Mazda/Ford
  Similar Threads
Mazda/Ford
