headlamp polishing
mrpilot
91
1,508
how n what product did u use to polish yellowish headlamp. (after sanded using 1000-2000 sand paper)
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
saw my friend DIY clean his headlamp wif 1500 grit sandpaper and he finish it off with autosol...
shiroitenshi
3,676
170
Got commercial headlamp cleaner too, but still will go yellow under the hot sun within one year.. have to polish, then go spray clearcoat.
shiroitenshi
3,676
170
No, car polish only works for glass headlights..
home repair tricks
Use finest sandpaper you can get.. 800-1500 grit... work your way to the highest number.. if minor, use 1500 first, then use 1500 again, but this time use it wet..
Then a lot of people don't know this, but toothpaste is abrasive also, and way higher than 1500 girt for finishing.
Good tip for repairing old car plastic headlight, this tip does not work on glass, obviously.
Hi,just want to ask regarding change ownership.
My father passed away last year,so im using his car now and want to change the ownership to me.
What is the standard procedure for this?
What documents should i prepare to bring to JPJ?
