F farhan al mustaqim Junior Member Nov 18, 2013 7 0 501 Kota Bharu Nov 19, 2013 #1 Helow sifus, do porting the intake manifold and remove the butterfly valve realy give gains? For h22a ngine,
pwhyze 500 RPM Senior Member Mar 1, 2011 924 356 1,563 Kuala Lumpur Nov 19, 2013 #2 farhan al mustaqim said: Helow sifus, do porting the intake manifold and remove the butterfly valve realy give gains? For h22a ngine, Click to expand... Yes, porting does help. How do you propose to control the throttle without the butterfly valve? Last edited: Nov 19, 2013
F farhan al mustaqim Junior Member Thread starter Nov 18, 2013 7 0 501 Kota Bharu Nov 19, 2013 #3 I don undestand, what is the purpose of butterfly valve for throttle
pwhyze 500 RPM Senior Member Mar 1, 2011 924 356 1,563 Kuala Lumpur Nov 19, 2013 #4 Well, the only butterfly valve I can think of in the intake system is the throttle body, no?
F farhan al mustaqim Junior Member Thread starter Nov 18, 2013 7 0 501 Kota Bharu Nov 19, 2013 #5 Yes, but for black top h22 , it has iab valve, in the intake manifold, but for euro r h22, it doesnt have it, do u own h22a motor?
^pomen_GTR^ 7,000 RPM Senior Member May 13, 2010 7,509 1,690 1,713 The Mines Nov 19, 2013 #6 more or less its like the variable intake manifold a.k.a iafm u want to gain some u must be prepared to loose some
pwhyze 500 RPM Senior Member Mar 1, 2011 924 356 1,563 Kuala Lumpur Nov 19, 2013 #7 Ah I see..An IAB valve..thought you meant the TB
F farhan al mustaqim Junior Member Thread starter Nov 18, 2013 7 0 501 Kota Bharu Nov 22, 2013 #8 Wat is low end power? and, what about de fuel consumption if porting the intake manifold and remove the iab valve
LOPI Known Member Senior Member Feb 28, 2006 99 4 1,518 melacca Nov 23, 2013 #9 U will loose low end power but better gain for high end power...fuel consumption wont effect much... Any reason u want to modify your dual runner intake manifold?
F farhan al mustaqim Junior Member Thread starter Nov 18, 2013 7 0 501 Kota Bharu Nov 25, 2013 #10 coz i heard do it like that wil increase de pawer, ... and, what is low end power? it is the power created at low rpm.?
