gti std mode & extreme: anyone? pls share
ABV9750
i try to make this forum interesting by adding some technical knowledge by sharing each other so that we knew what to upgrade correctly with minimal cost.
basic mode:-
1. exhaust system
2. air intake flow
3. electrical - spark, charging, setting
4. fuel flow and control
5. braking system
6. firm suspension - adjustable
intermediate mode:-
1. engine balancing
2. hi cam with cam pulley
3. option chip
4. lsd
5. transmission - close ratio gearbox, tripple clutch plate
6. 1.6 engine block + piston
7. lightened pulley
8. PU bushing
9. RSM, SAFC setting
extreme mode:-
1. turbo charge
2. e-manage
3.
please add if i miss out :proud:
i started by add in some info
basic mode:-
1. exhaust system - as discuss..4-1, 2" pipe, bullet and Straight flow tail
2. air intake flow -
- open pod - HKS? K&N?, apexi twin flow? mesh evo type? blitz?
- drop in ??
- air flow - SR20 MAF sensor? SR20 Throttlebody? Ram pipe? Cold air intake?
- porting / polish
- spark plug - normal NGK/Denso?, platinum G power? iridium? lodge golden? brisk 360deg? splitfire?
- plug cable - ultra racing? NGK power? other OEM? Nology?
- plug coil - MSG blaster 1/2? nology?
- charging - 70A/90A alternator? voltage stabilizer+grounding? I-charger?
- bigger fuel pump - bosch? vtec? SR20?
- Fuel pressure regulator -
- fuel catalizer?
- bigger injector - vtec?
- copper fuel pipe
5. braking system
- brake pad - metal king? endless?
- brake disc/caliper - cross rotor? braided hose?
- brake pump - bigger pump & servo?
6. firm suspension - adjustable hotbits? suzukisport?
- absorber - Koni? GAB? Ohlin? custsomize?
- spring - Apex? terra? hotbits? eibach?
i expect more info from others since this is the familiar mod among us.
thanks in advance for sharing
From what i have experience,
The suspension of suzuki sports is really fantastic for hardcore driving coz it make ur car really stable during corners. But for the confort there is none.. more worst during the bumpy road..:mad:
so, in my experience with my girlfrens.. they all hate it.. hehehehe..:biggrin: coz it make their boobs getting strecther.. hahahaha....:itsme::thefinger:
A thread every 60 seconds
