Gsr Rs lag/no power and response issues.
Wira3047
140
Selangor
Hi Sifus,
I am using a GSR RS and recently my conrod bearings gave away.
I have changed all rods and bearings,the foreman also polished the crankshaft as the bearing mounts were kinda giving away.
I had also installed exedy 3 puck clutch plate and adjustable cam pulleys(Not tuned yet).
I have a tial wastegate fitted with fuel regulator.
My car is not powerful at all as to no pick up and the response is slow.
I'm boosting at 0.5
It used to be powerful when i used a normal downpipe before however now there is no power at all.
There are no leaks as i have checked for any.
I need some advise as to where should i focus on fixing this issue.
Appreciate your help and inputs.
Thx,
Ruben
nash5272
20
Haha...
Not Sifu laa but I've been playing turbo
For 15year already...
There are only 2 thing Turbo not powerful...
Setup & Tuning...
Need me to say more need to view your
Machine then only can advice...
Interested SMS/call me 01128823913
chrissyong
975
14
hello bro,your gsr is stock boost 0.5 bar? just up the boost or drop some fuel pressure,make sure you already finish your engine run in or break in,hope can help you...
Wira3047
140
Selangor
Haha...
Setup & Tuning...
Bro....thx I'll call you
---------- Post added at 05:52 AM ---------- 6 hour anti-bump limit - Previous post was at 05:50 AM ----------
Bro not stock boost. ...m using 0.5 spring rate for the wastegate.
The issue is it lags terribly.
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
before tis issue arised, what hv u done?
is the adjustable cam pulley set already? the timing correct?
how big is ur current downpipe compare to before? too big will cause u lag as well
Hi bro's,:wavey:
Need advice on how to open my center air cond frame for my lancer E3 dashboard, my existing one got cracked so i bought a used one from mudah yesterday. I went to a shop and they quote me RM80(labour charge) just to install the frame. Anybody got any experience to DIY? i really appreciate your advice....:adore:
