gear R delay
faizaal
9
39
sepang
check gearbox mounting dulu. dan juga level ATF. kalau level ok dan mounting ok, gearbox kena overhaul.
level ATF OK.cuma mountig blm check.klu prob gearbox kat mana tempat yg terbaik nk buat lokasi lembah klang
sanekit
Dec 9, 2015
1,616
157
663
ada satu di subang. Win Tech Auto. boleh cuba call Mr Leow - 012 638 8316. overhaul gearbox dalam RM1200-RM1500. kalau bajet ketat, cari halfcut la kot. tapi halfcut condition kita tak tau macam mana. selalunya gearbox halfcut oil seal banyak yang dah problem dan clutch dah terbakar.
tapi workshop ni memang ok. saya pernah hantar gearbox auto 1.8, memang elok takde problem dan smooth.
Can try adding one bottle Lubegard atf additive in before opting for overhaul. Might help......
hi guys..recently i converted my auto waja to manual..but still using the auto ecu..i still have the manual ecu.questions :
1) is it ok for me to use auto ecu on my current manual waja?
2) is there any decrease of performance or side effect if using auto ecu?
3) will there be any problem if using auto ecu on manual car?
4) if i want to change to manual ecu, do i have to do wiring/harness all?
5) if i want to install e-manage blue,will the ecu gives any difference if using auto ecu or...
