Funny Problems (Kancil)
Freedom_Blue
KUALA LUMPUR
I am currently facing some problems wz my kancil 850cc year 2000 manual.When i realise the clutch after changing gear there will be a slip before it gets on gear.There is also jecking when i run around 80kmh-100kmh.I have done normal service and change spark plug but still have that same problem.Need some help from all kancil sifu'sss around.Is it clutch plate or clutch pump/cable.Need urgent help..........
do you check your clutch............may be clutch slip????
Hi, maybe u should try checking your clutch plate, maybe the clutch plate has worn out d. Then make sure the free play of your clutch pedal is set properly.
Just my 2 cents... Please correct me if I am wrong. Thanks...
A thread every 60 seconds
