Finally getting rid of my 4g13
Ranjanmax
121
518
this can only tell you what head it has. On the head, right infront, just over the extractors.... if i remember correctly on its right (facing the car)
block u pandai pandailah....
i hope you know what ur doing, i didnt mention this earlier but i believe one of the links posted by you was that of a newer generation engine, which means its not practical to put into the older protons. thats why its cheaper, cause not much demand.
**take note the newer gen 4g cannot rojak with the older gen parts, its 'terbalik'
Understood, take your advice also. I'm making sure the engine is from the CK or a mirage itself la to save me the headache.
lsm1991
1,469
185
PJ
ck is the 'terbalik later gen ya'
mirage refers to the whole range older and newer range...
the engines look diferent, should be easy to tell apart
  • Like
Reactions: Ranjanmax
Hi all. I see that the RadioStar section has little to no activity in the last few years. But I am hoping there are still folks out there monitoring it.
I have been given a new RS0591 and have installed it. Almost everything seems to work fine, except I problem trying to engage Turbo / Short Run.
The unit will flash the lights, and turn the LED on, but after a couple seconds the LED goes out, and when I turn off the key, the engine stops.
I presume the LED goes out first because...
