Exhaust question ~
Wilson13B
296
30
528
Just replace the rear muffler with a straight flow unit.....the problem is it sound quite nice and bassy when at idle to mid rev range.....but once the engine run to high rev range the engine sound more loud then the exhaust sound....does removing the centre bullet can help this,what about the performance?
fyi,the ride is a Kenari with 1.8 inch piping,cylinder centre bullet and straight through rear muffler with a L9 Turbo engine coupled with a TD04 turbine ~
Thanks for any info ~ =)
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
1.8 inch aaa? why not go all the way to 2 inch? maybe your exhaust is stuffed at higher rpms? which no good for a turbo your size hehe
rather than use a center bullet (cylinder thingie wif some sound-muffling packaging), better use resonator (same as bullet but w/o said packaging, just a hollow pipe with a bit enlarge body)... how to differentiate between the 2? if you 'jentik' the bullet, it produce no sound... but for resonator it gave a loud 'TING' sound
for example my exhaust setup for wee original RHF3 turbo in a L5 engine.. its an original FGK Power Getter unit originally for Mira L5 4cyl turbo.. description is in the pic
From cat converter (no money to do custom downpipe yet huhuhu) to mid muffler
From mid muffler to tip... you can see the resonator near the tip
The sound? at idle it sounded like this (if inside car, you felt the engine is louder hehe)
‪My exhaust sounds after converting to FGK single pipe version‬‏ - YouTube
after 4k rpm it progessively louder and louder... but still bassy and it won't resonate inside the car, rather the bassy loudness heard as if it was a few meter away at the back of the car at high rpm
so by logic, if you go 2inch all the way + 1 resonator + biggest 2inch muffler you can fit = nice burbly, bassy and progressively louder zorst setup
or... you can consult one of zth thread that discuss such topic here http://www.zerotohundred.com/newforums/car-modification/128441-exhaust-modification-corner.html.. the thread starter also owns a exhust business hehe
Wilson13B
296
30
528
Today removed the Silencer ~ when idling it jst like the Subaru Impreza Boxer ~ Sweet :love:
Where can custom a downpipe ar?
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
i wrote downpipe? i meant dump pipe hehe
you're using td04, surely use custome dump pipe maa...
My car has been stolen, it is Championship White has a black Cwest front lip and a black Mugen spoiler in the back. It also has silver enkei rpf1 rims. Liscence plate number is WGD 6800.
If you spot it let me know here via PM or email me at [email protected]
Thank you in advanced for the help...
