Well said...IINM the camshaft profile is slightly different and there is minor variation in turbocharger
Other than that there are no difference
And oh yes,stock EVO Turbocharger never did come with Ball Bearing
EVO Hood/Trunk is always made from aluminum(CT9A anyway)
Aluminum roof only on CT9A after EVO VIII MR and no sunroof
Evo8 rear trunk is not aluminium, it is damn heavy metal. don't believe? take out yours and see.IINM the camshaft profile is slightly different and there is minor variation in turbocharger
Check on this web.Hi All Sifu ....
hope your all can comment what the different between Evo 8 MR engine (internal ) VS Evo 8 engine?
beside for the ball-bearing turbo, Cam shaft .
izzit Piston they using the same ? ....
Thanks for comment ....
that's him,Check on this web.
http://www.lilevo.com/mirage/EVO 8 MR/Evo8mr/Supplement/Technical Info.pdf
Hope this will help
Actually what you said above is more or less applies to USDM Model but not JDM Modelthe different MR version wth others ver 8 they came with a revised limited-slip front differential, aluminum MR shift knob, handbrake with carbon fiber handle, 17 inch BBS wheels, aluminum roof, and a 6-speed manual gearbox. The new Evolution also sported chrome housing tail lights and head lights.MR also uses slick-response Bilstein shocks for improved handling. Detail improvements have also been made to Mitsubishi’s own electronic four-wheel drive, to the ACD 5 + Super AYC 6 traction control, and to the Sports ABS systems.
