engine suddenly jerk
mrevo
86
Hi everyone, i'm driving wira 4G93T GSR engine. yesterday my car was suddenly jerk during driving. aAt those time the RPM is arround 2k to 2.5K. After that, it was happened quite often but it doesn't happened in idling time.
Is it a sympton of broken fuel pump? or ignition problems?
I opened the spark plugs but it looks normal, brown colour.
so, what is the problem actually? is it also come from my FICD that i installed?
liz@rd
492
57
probably u need to re-tune ur FICD , yes my FICD setting on my 93na also will run @ times , just go back to where u installed it then ask them 2 tune it again ...
lonelylilpig
832
33
B4 this i encountered this prob oso, check fuel pump check coil , check any other possibility still kenot detect. After that try exchange with frens ECU then ok D....
I don't will that work with your car as mine is not same engine as yours .......
mrevo
86
actualy,i,m using the FICD quite long..since a year.if this consequences come from FICD, it may occured since installation . Is that same prob happened to u last time?
mrevo
86
did u wash your engine bay recently?
your plugs might be wet. happen to my car before.
I didn't washed my engine. No..my plug is in normal condition coz already checked.
Bump: Does anybody knows how to test the fuel pumps?
PAHAM
195
I think ur coil have a problm..already too old..need to change new...
koMie
90
1,508
just install PS...can settle yr prob bro....cheap n manual tune....
Bump: just install PS...can settle yr prob bro....cheap n manual tune....
Turbomaster1
431
the only way test fuel pump is pressure test....connect a pressure gauge in between the fuel filter and fuel rail......pressure should go up as you rev harder....off engine... it should stay for while....
jerking prob normally happens if got coil/ plug cable damage......injectors do not normally fail unless it has been unused for a while.....
engine tuning also can effect during acceleration....if got management....
cheers
Lotus Cars Australia released a special edition Exige Sport 240 to the Australians. The name 240 signifies the 240 horsepower based on the existing Lotus Exige.
The Sport 240 features an increase of 10bhp from its base engine and 11ft-lb of torque after fuel injector and ECU upgrades. The engine is a supercharged VVTL-i 16valve 1.8-litre, intercooled. 0-100km/h comes in at 4.2 seconds...
