misfiring and jerking..help help!!
karl_razlie
514
56
5,028
Puchong
hi guys need ur help...may turbo car jerking at idle and misfiring semput when reach 2800 or 3000rpm onward...already change new plug, fuel filter and already check coil and plug wth multimeter all seem ok...but this prob still happen..btw before this things happen, after one week i realize one of my vacum line to std fuel regulator tercabut ...after that than this thing happens...now kapla pusing no clue what happen to this car..hope u guys can help me...
karl_razlie
514
56
5,028
Puchong
plug cable not change yet...but already check wth multimeter seem ok to me..hehe..or maybe try change first....
DanzEterna
15,911
3,371
3,213
PJ
www.primeperdanaclub.com
how accurate is the multimeter? maybe accurate while idling but not above 2k rpm,
try swapping with your frens one 1st, if problem persists, then its not the plug cable.
karl_razlie
514
56
5,028
Puchong
ok bro..but if already change coil and plug cable..this prob still apear what should i check...is weak fuelpump can perform this simptom??
DanzEterna
15,911
3,371
3,213
PJ
check your fuel pressure reading.......1st,
fuel pump might be the cause of the problem...
---------- Post added at 03:36 PM ---------- 6 hour anti-bump limit - Previous post was at 03:35 PM ----------
check your plug cable is in order if not mistaken is 1-4-3-2.
u double check wid your pomen.
GSR06
455
17
Try to change plug cable, fuel pump, injector, etc...I had similar problem during acceleration only and not during low RPM.
flanker c
76
9
1,508
misfiring= ignition problem..check spark plug gap...good gap 0.5mm -0.6mm..if over this number your car will missfiring..
