Engine Balancing
najibkl
398
www.protonclub.com
Hi folks,
Anyone here have experience doing the engine balancing? What i know, for make ur engine more lighten.
Is there any reliable to this?
tajulsans
1,449
9
Soo Bang
balancing and lightening is normally done concurrently.. the reason for lightening is to reduce unspung weight in the engine so that ur engine can rev up faster whilst balancing act to balance up ur crank, conrod and pistons.. the rational is same as wheel balancing.. if ur wheel is inbalance, u will feel it vibrating at high speed.. for engine internals, vibration = more wear and tear.. therefore the reason for balancing is to reduce vibration and makes ur engine more free revin.. properly balanced engine can be rev up 9 9 with less worries..
noeyedeer
91
what is the total cost for the engine balancing?
cipan_supercas
1,698
7
Shah Alam
www.draxecu.com
Estimation only arr.....
Potong crank (pisau style) = 150
potong conrod = 40 x 4 = 160
potong flywheel = 40
potong piston = 60 x 4 = 240
potong cylinder head = 60
Balancing = +-700
other cost:
overhaul gasket set = 250
some extra oil seals = 150
New clutch set = 400 to 1800 (Depends on what brand larrr..)
New lubricant = 40 to 200
New transmission oil = 30 to 200
Power steering fluid = 20
workmanship = 400 to 700 (Depends on which workshop u send).
if efi engine:
minimum SAFC = 800
or e-manage = 1200
tuning cost = ????
Dyno = ????
if turbo:
turbo porting & clipping = 700
if carb:
tuning =????
Hidden cost:
Drinks = ???? Don't know how much u need to drink while bikin sebok at the workshop.
Fare/petrol = Bus/Taxi/pinjam kereta
U got the picture?
tajulsans
1,449
9
Soo Bang
the cost for balancing alone is about 5xx-7xx, provided u dismantled all the stuff and the shop only do the balancing job.. if involve lightening than diff story already..
then come the other cost for changing bearings, gasket etc..
cmng
3,289
72
convert or buying a second hand engine
do it guarantee it perform flawless like complete rebuild engine ?
taqu
207
Hmm engine balancing ar? Factory engine already excellent without any need of balancing, for upto its normal operating range (6500RPM). To push stock engine originally designed to rev upto 6500RPM and going towards 8000RPM and above, that's where balancing,lightening & rebuilding comes into place.
Personally I'll stick to 8000RPM at most, going above 8000RPM will make ur car no longer suitable for normal driving.
rollakid
4,936
5
Kuching Sarawak
Originally posted by Ronald_loulan@Mar 1 2005, 22:03
But the cost is too high...
Not worth la...
if you want play NA, no choice bai... every horsepower count
if i were to transplant a new engine into my car cuz balancing and lightening is too costly.. i'll probably balance and lighten the transplanted engine too :lol:
vestax
1,573
7
Damansara Heigh
www.fivio.com
now days with high tech machinery , the stock engine from the factory are balanced pretty well already . like taqu said , unless you're looking forward to make the engine rev higher then the stock specs then you may balance the engine .
cmng
3,289
72
now day with high tech machinery
i think those want to balance is more like old engine
VR4,SR20,B8,B6.
not like newer EVO so on
najibkl
398
www.protonclub.com
Most of the NA engine very heavy. Thats why needs to do balancing for smoother & lighten. Fuel comsuption as well too.
After 2-3 years ur engine doesn't seems like good.
MitonCT26
1,112
9
Seremban
if you want more engine response and free more rpms, engine balancing is the way to go.
please...please do this when you are rebuilding or overhauling your engine...not open up simply to balance.
lightening and balancing is a diffrent process. so...get your parts lightened first before balancing it.
as a balanced engine user...every penny spent is worth the effort. ;)
r2d2
RM300 0nly... f0r balancing...
kapak/p0t0ng crank RM 120
lee br0thers sg besi....
hello to all bro......need to ask u all do u have any saga owner here coz now time i jz bought a saga 1.3.and now i wanted to change the enjin but only got two choice,1.mirage 1.6 turbo 2.mivec 1.6.the question is anyone here know which workshop can help me to settle this proplem??pls pm back,tq
