i use UR 19mm bar. cost me rm500 [U-braket&bush + 555 link rod]. and this link, not use L-braket to link wit ARB fr arm. just direct mount! same wit ek4.. [ori arm hav 1 hole only]Hikaru said:david, basically you can use the EK9 but you gotta drill new mounting point for the EK9 ARB:
http://img.photobucket.com/albums/v486/jayswift/Build%20Up/DSC03412.jpg
shfish said:Wow looks good man, did some research and most of them recomend just an additional metal plate bracket at the back of the existing U bracket to brace the chasis. BTW the ASR wil cost about USD256 a pop.
I'm quite sure ur EK9 antiroll has been installed up side down. It should be in "M" position instead of "W". Hope u get wat i meant. I've this problem b4 bcoz the exhaust workshop want to prevent the antiroll bar block the exhaust. After I switch back the normal possition it is OK now. U might need to modify ur exhaust piping for tat. One more possible reason, are u sure it is EK9 antiroll bar? DC2 antiroll bar will have knocking sound if installed on EK also.shfish said:Anybody has encountered problems when they install EK9 anti roll bar on a EJ 4 -door chasis where the EK9 anti roll bar is knocking against the back suspension lower arm after installation. Please advise.
JINEIL2EN said:any dealer in Malaysia..???
sry out of topic but its ok to use dc2 arb on an eg rite??...it fits well wif the eg6 armsasuke said:I'm quite sure ur EK9 antiroll has been installed up side down. It should be in "M" position instead of "W". Hope u get wat i meant. I've this problem b4 bcoz the exhaust workshop want to prevent the antiroll bar block the exhaust. After I switch back the normal possition it is OK now. U might need to modify ur exhaust piping for tat. One more possible reason, are u sure it is EK9 antiroll bar? DC2 antiroll bar will have knocking sound if installed on EK also.
