ECT-S manual or power
innsand
Sep 25, 2011
19
Kedah
hi to all sifu here. i wan to ask regarding function of ECT-S manual or power which got in the my dashboard. under the speed and rpm meter. some of my fren said it is to gain more power when push the button to power instead of using manual. but is there anyone know what is the actual function? is it change the gear ratio or sumthing??:confused::confused:
meg_omen
421
96
3,028
Home - Klang; O
rpm level where the gear normally change will be higher...:biggrin:
it's actually similar when you 'floor the throttle pedal'...
suma_
303
7
DU
normally 'manual' will shift gear at rpm less than 3k. power mode gives you more rpm, hence feels more power. but if u get used to manual, you may notice that u can shift gear faster.
Need all sifu and mahaguru help here. Can i know which one better, a lighten adjustable cam(aluminium) or a normal adjustable cam(steel i think)?? And what the different of this two adjustable cam in term of performance??And last question is, i still can use adjustable cam rite although i still use normal duration cam??
Thanks for viewing n your comments..
