Easiest swap for a 2005 Lancer cs3a with a 4g18 engine and a Manual f5m411 gearbox
jay_lancer
292
70
28
Thailand
I have a 2005 Lancer cs3a with a 4g18 engine and a Manual f5m411 gearbox.
I would like to know what engines use a block that would be compatible with my f5m411 manual gearbox and would give me a bit more power while retaining the same bellhousing, gearbox and clutch etc.
I have read the 4g9x engines maybe compatible with my gearbox but not the 4g6x engines, is that true?
A 4g92 MIVEC with 172bhp would be my first choice if this is the case, but a 4g93GDI with 148bhp or a 4g94GDI with 145bhp would be OK too.
I live in Thailand but I know you guys in Malaysia know alot about these engines because a lot of Proton models are mechanically similar to my Lancer.
I know where to get engines and halfcuts here but most of those have Automatic but I prefer to keep my manual gearbox.
There is no restrictions on putting older engines in newer car's here.
Because of the heat I would rather go for a N/A engine swap than a turbo on my existing engine. Also I like to keep my car fairly standard looking on the outside so don't want to mod the bumper for a FMIC.
Many thanks in advance for any help, advise or links to previous builds.
cheers
Re: Easiest swap for a 2005 Lancer cs3a with a 4g18 engine and a Manual f5m411 gearbo
cheers
get the 4g93 GDI-T the best balance between fuel consumption and power increase...... and if not mistaken u still can maintain using your 4g18 manual gearbox.. (not 100% sure but u need to double check with your mechanic)
jay_lancer
292
70
28
Thailand
Many thanks for the reply :)
hey guys... i just want to ask.. if let say i instal lowering spring.. will there be any bad effect on my car??? ehe...
