whatdamn said:malyadayada,
are you sure that the braking power has increased or are you in denial that your statement is exaggerated? heheh.
but seriously, if you plan to DIY something to cool your brakes, your money should be spent on buying some 3 inch/2 inch in diameter hoses and route them from your front bumper (most likely where your spot lights have been) and place them behind the steel plate located on the inner side of your disc brake assembly.
wat car r u driving bro?? get brembo max .. damn superb..!!! heheheeAhLun said:Anybody got DIY drilling hole on disc brake before?? LIke those Brembo type. Got many holes on the disc brake. Will this shorten the disc brake life span?
Ya.. i also thought about this before..whether the disc rotor will crack or not. I think better stick a OEM is the best.g88 said:drilled rotor help in cooling down your rotor faster hence brake pad won't overheat
If you don't have machine to do or just thinking to use the normal drill i suggest you NOT to do it. Check in google you see what ppl said. your rotor will crack so do your brake pad = no brake very dangerous..
Bro.. Money man...:emoticon_U:@zri said:wat car r u driving bro?? get brembo max .. damn superb..!!! hehehee
