Double Din
-lanz-
147
10
Perak/Kedah
I own Waja.
Just planned to replace stock blaupunkt head unit with double din.
Wonder which brand is good Pioneer or Kenwood?
So far found Pioneer AVH-8850BT and Kenwood DDX9016S are the latest model but the price is 2K plus.
I need a nice double din which supports good AV,mirrorlink and reverse camera.
Any suggestions or experience?
6UE5t
6,000 RPM
6,756
1,300
All depends on the budget and what functionalities are critical for you, then only choose which one fits the best. Both Pioneer & Kenwood IMHO are equally good enough for my amateur ears. I have owned several cars using both brands, no issues with them apart from 1 power button on one of my Kenwood which came off.
Yah! both Pioneer and Kenwood are okay. I have been using JVC ones since I was working there last time also not bad....
This simple circuit makes it posible to monitor the charging process to a higher level.
Final adjustsments are simple and the only thing needed is a digital voltmeter for the necessary accuracy.
Connect an input voltage of 12.65 volt between the positive and negative poles and adjust the 10K trimmer potentiometer until Led 10 lights up. Lower the voltage and in sequence all other Led's will light up. Check that Led 1...
