found it at another forum through sites...interesting....FYI
First take the length and width dimensions of the part of the headlight u want to cover. then just take some sheetmetal, and cut out 2 pieces.
Then bend over one edge, so you'll get a nice clean side at the bottom in the end.
Next u just start bending it into shape so it wil fit your hood, and wont hit your headlight, and it'll line up right with the hood between the headlights.
Next u just start welding it, little by little so your hood wont bulge because of the heat
We put a little piece of plate in the upper left corner of this pic, so when done it matches the stock shape of the bumper.
Then just grind it smooth.
Seal of the inside, so corrosion does not have a chance to appear
Done, on it's way to the paintshop...
And the result in the end.... i think it looks very good if i may say so myself...
Notice the shape of the upstanding part of bumper between the headlights matches up with the hood... like it's oem...
this one on crx...maybe can be done on others model....just to get rough idea
:D
:D
