if DIY-ing was that simple it'd be called 'manufacturing' already. keep on trying dude. I didn't learn my DIYs in one day.
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
Post some pics la....
ok...my story or 3rd brake like starting like this...
as the original LED becomes older...rotten into bits and pieces as u can see in this pict (lower is older version) being replaced by those flexible LED
later i use 2 row of this flexible LED to make it even brighter
the result is like this...nice but not for long....i dunnow why but this cheap LED died after few months...
so i replaced with the DRL cum 3rd brake light.. (i'll get the picture later) :adore:
TitanRev
Mar 3, 2005
8,180
3,678
I also have the same findings like you pomen. Seems that does drivers for the LEDs is not very good.
stupidcar
5,000 RPM
5,567
850
Aih, I just did one miscalculation only, Izso. haha.
As you can see, it works but it just doesnt fit in nicely in my Persona kit.
I need to re solder so I can make it thin.
I had everything figured it out just I'm not good at being creative or artsy.
alantjw
1,566
128
you use glue gun instead of soldering iron?:hmmmm:
stupidcar
5,000 RPM
5,567
850
me2kimi
717
276
1,563
Puchong
you can use this can of breadboard for trial and error. no need solder or glue. all parts can be reusable.
Hi! just want to ask an opinion, which is better Garret AR60 or TD05H with 20g Fins for my 63T engine, some said goes with TD05H and they're others that said AR60 is much more power then TD05H, is AR60 is slightly bigger then TD05H or same? need some opinion & guide here plz :adore:
