DIY – Perodua MYVI 1.3, Installing the Simota Replacement Air Filter
autocrazee
1,088
11
638
www.fasmoto.com
Replacing the stock air filters with an aftermarket version is the simplest way to improve your vehicles performance, longevity and economy. The Simota/Works Engineering Replacement Air Filters are quality built to high standards, plus improves performance and fuel consumption through rigorous research and development. Here, you will see the simple steps needed to replace your stock air filter with an aftermarket air filter for the Perodua MYVI 1.3. Other vehicles may not vary much in terms of installation.
We know this is pretty simple, but hey, never assume right.
Step 1
Find the right air filter and purchase. We at 12v.com.my carry a number of air filters for various makes and models. Get yours today!
Closer look at the Works Engineering Replacement Air Filter
Step 2
Open up your hood and get to work. Locate the air filter box and unclip the cover. There are six clips holding the box. With the cover off, you’ll see the stock air filter, begging to be replaced :)
Unclip these.
Unclip the six clips that hold the cover
The Stock Air Filter
Step 3
Take the stock air filter out and dispose of it. Put the new Simota/Works-Engineering Replacement Air Filter in it’s place. Make sure the right side is facing up.
Air Filter Comparison
Stock Air Filter and Simota/Works-Engineering Air Filter Comparison
Make sure to place the filter correctly
Step 4
Put the cover back onto the box, and reclip the 6 clips, and you’re done! Good Job!!! Take the car out for a spin now, you know you want too ;)
For more info, kindly visit 12 Volts - Malaysia's Premium Car Audio & Accessories Online Store : DIY - Perodua MYVI 1.3, Installing the Simota Replacement Air Filter
GOOD LUCK D.I.Y.ers'!!!
autocrazee
1,088
11
638
www.fasmoto.com
Hi,
For this installation, it's not going to be possible to do a review. Mainly because it's a showcar that isn't a daily driver and we don't really get access to do so at the moment.
We hope to do a proper review in the future, and when we do, rest assured we will post it here :)
Thanks for the interest tho.
Regards
I own a Saga Magma 8V and I just wanna find out from all the sifu here if my engine can support the compression made by the NOS boost??
