Diagnostic Trouble Codes - 1991 Subaru
Victor520
Oct 20, 2012
27
8
503
www.chinasinoy.com
11 Crank Angle Sensor (No Reference Pulse).
12 Ignition Switch.
13 Cam Angle Sensor.
14 Injector 1.
15 Injector 2.
16 Injector 3.
17 Injector 4.
21 Engine Coolant Temperature Sensor.
22 Knock Sensor.
23 Air Flow Sensor.
24 Air Control Valve.
31 Throttle Sensor.
32 O2 Sensor.
33 Vehicle Speed Sensor.
35 Canister Purge Control Solenoid.
41 Air / Fuel Learning Control Function.
42 Idle Switch.
45 Atmospheric Pressure Sensor.
49 Air Flow Sensor.
51 Inhibitor Switch (A/T).
51 Neutral Switch (M/T).
52 Parking Switch (A/T).
Extracting Trouble Codes:
The self-diagnostic system operates in two modes, a Regular Mode and a Test Mode. In the Regular Mode, components necessary for proper starting and driving are monitored by the control unit. If the control unit detects a malfunction in the Regular Mode, the ESC or Check Engine light will be lit by the control unit.
To diagnose the system, the Test Mode must be accessed. This is done by first turning the ignition OFF and connecting the Test Mode connectors (two wires with "T" shaped connectors located under the left side dash ). Then turn the ignition ON and read the trouble codes as displayed by the red LED on the control unit which is located under the dash.
Trouble codes are represented by a long flash for the first digit and a short flash for the second digit. For example, code 23 would be represented by 2 long flashes and 3 short flashes. If more than one code is stored in the control unit's memory, the codes will be displayed in numerical order. When the system has been restored to normal operation, the trouble codes will automatically clear from the control unit's memory.
I thought this would be the PERFECT test car for the Castrol Edge as being an old car, this will really test out its protective properties. Also, it’s a heavy car with a 2.8cc engine so fuel consumption is generally on the high side. Since owning the car in December 2009, it’s been running on an average 6.3 – 6.4km per litre of fuel. It’s on a strict diet of RON95, being my daily drive and the ever rising cost...
