lower than 8 got problem?something wrong wif the piston?khoyos said:remove your spark plug, place the compression tester at the plug hole (meaning compression tester takes spark plug place) and crank the engine usually up to 5-6cranks to get reading. usually for turbo, anything lower than 8 should be considered "ada problem"...
ask your mechanic to do it for u. most probably they wont charge u for doing a compression test. u cant DIY unless u have the compression testing tool...
Yeah, if it's too low, then you're losing compression somewhere. It could be that the piston rings are worn out. Or, a bad case would be your engine head is screwed, like in the case of my pal. It's probably due to detonation - the valve seat has a nick in it, so some fuel-air charge gets squeezed out from the nick during the compression stroke, leading to compression loss.mi_scuzi said:lower than 8 got problem?something wrong wif the piston?
