compression calculation
aarion
609
Hi, i was wondering how to calculate compression ratio. My current na is running on 15:1 compression and i planning to turbo charged it. I'm using a standard 1mm gasket.
If i use a 2mm metal head gasket, how much will the compression be reduced? Please give me some light into this matter. Thank you.
Joeker
Walking Dead
3,580
62
Jinjang
To calculate Static compression ratio, need to know the block's bore, stroke and head's dome volume.
Or
Do it manually at workshop using a pc of glass panel and brake fluid,
Formula, (c + hv) / hv
Eg.
Piston@BDC, 500ml, being c.
Head's dome + head gasket, 50ml, being hv.
(500 + 50) / 50 = 11
Therefore, static compression is 11 : 1
BTW, your compression 15 : 1? CI engine?
aarion
609
i'm running a 4g93p block with Mivec head. Using 4g92p high comp pistons.
bore will be 82 and stroke is 89. but don't have the dome volume.
cooljas
523
15:1 is not ur compression ratio....tat is ur compression test results!I think if u use the 4g92p piston on a 1.8block...the CR should be around 11.X:1
CarroTT
177
waaaaarr, 15:1 , engine diesel arr ? :adore:
here is a very useful tool that i use frequently,
Engine Calculator...
15 bar izzit ? :hmmmm:
at wat rpm ?
wira_tak_laju
4,184
if i am not mistaken..depends on which 92 piston u r running..3 version of 92pistons..92d-h frm local 1.6,92d-e frm 92 dohc non mivec and 92d-v frm mivec...since u turbochrging,why not use ur 93 pistons as its alredy 10.5.1 ratio..then either 1.5mm or 1.8mm to reduce the compression for safe application
cooljas
523
Bro, u got the codes wrong......92d-h is from 1.6dohc non mivec, 92s-h is from 1.6sohc(local), 92d-v from mivec.......
<img class="alignnone size-medium wp-image-35091" title="atom700_1" src="http://www.zerotohundred.com/wp-content/uploads/2012/08/atom700_1-600x359.jpg" alt="" width="600" height="359" />
Remember the Ariel Atom? This lightweight, no-frills, road-legal sports car once wowed Jeremy Clarkson with its out-of-this-world acceleration, having a 2.0-liter supercharged Honda K20A engine as a powerplant. And as a result, 0-100 in just 2.8 seconds and having his face almost being ripped off for not...
