Chop shop windshield
UniKorn
Dec 3, 2018
9
40
Hi guys, is it recommended to use a chop shop windshield to replace current windshield? Is there any disadvantage like easily broken because it was a used part.
Many thanks
ixeo
4,788
3,080
KL, Malaysia
Any reason why you want to do that? If the condition is good I guess no harm.
Better to just have windshield insurance, and change new one when the time comes IF your windshield is damaged.
Many thanks
I doubt a chopshop will look after the windscreen with finesse and detail. And if it's a windscreen that's on a halfcut and you want to take it out and install on yours - unless your car is super rare and impossible to find parts for, better don't.
Like my Sonata III, now worried as even body parts hard to find as no more chop parts....:smokin:
UniKorn
9
40
Ah, so there's a risk of the chop shop windshield has existing damages that we can't detrct
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
Easily broken?
nope.
Will it fit?
Of course if its from the same model.
Quality?
It wont be the same as new windscreen. U will never know the surface condition until u are driving in the rain at 20kmh as u cannot see inside.
As mentioned by others, better get new using insurance claim.peace of mind. increase the cover a bit and u can replace the windscreen plus good quality tinted as well.
Yup, because they need to remove from half cut and might get damaged which may appear later on only.....
UniKorn
9
40
I have thought about it. Yea depends, it might be worth it. Like our local cars are easily covered by insurance, get a new one straight.
What about the make of the windshield. Any idea which manufacturer is better? Or which to avoid
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
Windshield manufacturer are very few unlike other wear and tear parts manufacturer.
These manufacturer have to comply to strict regulation before they can supply to car company. I know of none which produce only replacement but dont supply to car company. So, safe to say no specific brand to avoid.
mind sharind whats your ride and your concern abt windscreen?
I remember my windscreen is China made if not mistaken, since I had it changed many years ago. My first change cost around RM1.1k and that was local made, few years later it cracked again, so when my mechanic source, say got one at RM600.....lol
jeheyr
834
19
5,018
Ampang Jaya
community.webshots.com
it's better to use Insurance cover rather than you bought the half-cut one.
In condition, if it only has crack you can wait for insurance renewal then add windscreen cover for almost rm100 if i'm right.
But then if there is thousand cracks, i recommend you go for halfcut which might be far more cheaper than the new one.
Depends on the screen. If laminated, it will crack but will hold. If tempered, it will shatter to pieces, that one need to change immediately.....
Welcome
I am concerned about my 175mm oversized crank pulley on 4a-gze. It is a Cusco pulley copy which is CNC machined. On low revs you can see it wobbling - on higher revs it is not visible however I am aftraid that it will wear out my crank.
I recorded it and here it is: YouTube - 4a-gze oversize 175mm crank pulley vibrations
Can somebody confirm that other oversized pulleys are perfectly balanced and do not behave this way...
