or swap ur blm with Danz P.tt with some top up!!yeah, u should have got a perdana twin turbo bro.....
but now its abit too late aint it...
u could get a BOT though.
ahaha..no thanks bro....if swap with R32 GTR with some top up i wan...or swap ur blm with Danz P.tt with some top up!!
u need to check your spark plugs & plug cables, the copper inside the plug cable might been cracked....sorry to butt in, but i got a quick question to ask... my brothers satria 1.3se has got a jerking problem in the low rpm's on all the gears...what could be the problem? thank u in advance!
bro, what u told was correct! the 3rd spark plug cable was cracked...changed to new same proton cables and now the car is fantastic again! saved me so much, cost was only rm65!thank you!just check on the minor problems 1st bro..
last time i used to encounter when i was using my SLK (small lil kencil),
my car suddenly semput2....i tot wat happened....so i called AAM, they came to my hse
& tried to rectify the problem, they told me i need to service my carb, overhaul engine etc....then i said ok la....will bring to wshop the next day..... i got worried the whole nite...cos $$$ gonna fly......
the following morning brought the car to fren wshop, he told me it was just a loose cable plug....so he pushed back in & job done.......the next few days the same thing happened, the cable plug always ajar...so i tied it with cable tied, after that never had the same problem again......
