Actually you found the problem, and it is the fan, so check on this. Best is when it happens test for incoming electrical supply. It will be difficult to check when it is working fine....hi guys, my ride a Wira 4G15, lately have some overheating problems that i cant seem to find the cause.
it only happens after the car is run for more than 1 hour, fan everythign normal, then suddenly fan wont turn and temperature go up.
i have changed new radiator, new thermostat, new sensor switch, new radiator fan motor but problem still there. water pump also brand new high quality item.
engine is all stock standards carburatorr
any bro experience this before? the fan just wont turn after a certain period. i cant seem to find the problem.
engine seems ok all the while no makan miyak hitam
wiring?
need to open head?? :stupid:
---------- Post added at 03:51 PM ---------- 6 hour anti-bump limit - Previous post was at 03:50 PM ----------
fan relay problem?
sighhhhh
hope no need to open head gasket
Some radiator fan run on the radiator temperature sensor alone and some together with air-con, so check which is yours?
