Car cannot start
Aug 19, 2015
Merdeka evening wen to midvalley. After hangout going back time car canot start. Car can crank as normal. But cant start.Battery is still OK.all electrical can be normal function. Open rear seat check fuel pump, pull out the outlet hose from fuel pump. On ignition, fuel spray out. Check infront fuel gt naik or not. Found fuel naik after on ignition. And the pressure aso high. Check for api. Place a wire at spark plug cabel and ground it. Found api. I have no idea wt course can make the car cannot start. Any idea y the car cannot start????:confused::confused::confused::bawling::bawling:
Fuel check at front is before injectors? Sure any fuel going into combustion chamber?
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
if spark plug cable no api means crank sensor...
but your case got api....i think try check cam sensor
EvolutionZ
5,000 RPM
5,027
1,448
i encountered before, its fuel pump. but you have troubleshoot there already....can share what went wrong actually.?
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
fuel pump faulty it wouldnt send fuel splashing if we remove fuel hose at fuel rail/injector rail...
(that kind of method i'm using on waja and many other car to if suspect fuel pump not working)
hello guys..
i already got e-manage..
but some people say..
chip wil incease more power n torque..
plzz state to me which is beter or put in both..?
plus izzit safe?
thanks..
