Can anyone please teach me....
simefly
449
same place same time??? i can try to join for a short while la... but i have to run some errands fers... hehehe
PocketRocket
'(00) Mod'er
11,164
953
3,213
Up Yours
ok dude....see u there...den i show u my michiba's..kekeke
rayz85
425
PJ, Sunway
simefly said:
Here you go Step by step
1) Pop your bonnet open.. Hahaha just kidding
2) Look directly behind your headlamps and you will see a socket connecting directly at the middle of the round rubber piece.
3) Press the clip and pull off the socket
4) Then remove the round rubber piece (tip: you can pull the ear/extending flap of the rubber piece). Just make sure you don't tear the rubber as you do not want to rear goldfish in it...)
5) there will be two sort of like bunny clips. It feels abit 'springy' Press it towards the front of the headlamp and pull it towards the side. Do the same for the other clip as well.
6) then hold the leg of the bulb and pull it out gently. DO NOT TOUCH the glass bit of the bulb.
Repeat steps 6,5,4,3,2,1 when you put it back. then get on to the next headlamp. Follow steps 1,2,3,4,5,6,6,5,4,3,2,1... you will be fine!
Happy removing then!
if touch da glass bit of the bulb den how ark :(
PocketRocket
'(00) Mod'er
11,164
953
3,213
Up Yours
MY 1ST DIY IS NOT ON MY CAR.....hahahahahaha
feel dam good,achievement~!! (^.^)v
khguan
4,818
26
Seri Kembangan
fotopic.net
use a tissue to wipe it clean....
when u touch de glass... ur fingers wil left some oil on the glass.. when de bulbs light up... it will be heated unevenly.... n cool down unevenly.. so this may damage the glass... by breaking.....
hey guys,
im planning to change my crank pulley to a lightened one..
just wanna ask,is Zerone one good ah?or should i get works?is it the same size as my oem pulley? mythelogy is too expensive la..hehe
