Bushings Problem?
dvino
92
10
1,508
Calling all sifu’s,
I think it’s time for me to change my bushings for my car. I start to hear metal knocking sound when the car start to move and every time I go through a speed bump( especially front left side). I just gone through shoulder surgery (some mishap) so I can look down under the car for visual defects.The problem is I don’t know which one I should change (definitely front). Can any sifu recommend me which bushing should I change by time? I think none of the car bushing has been replaced before and it’s a 04 PFL model.
what else could cause such noise beside bushings worn out issue?
appreciate the input
Thanks
markblurberry
115
20
518
Hi Bro,
Just my 2 cents, if you really gona change your bushing, might as well change all front bushes, very hard to identify which part is worn and which not....but u still need to check how many bushes/part available for your car...and also worth noting - the labor charges is not cheap...but after change all the bushes, your car feel brand NEW again...then can fell in love with your car once more!
zane_al
181
16
518
Yep change all the bushings then do on-wheel balancing and alignment then it should be good for 180km/hr drive.
hi...just purchased a momo gear knob (golf ball design) and trying to fit onto kancil gear. original kancil knob is screw on. when i bought it first n tried 2 fit it, used the supplied rubber adapter and then put the knob on top, some of the grooves on the inside of the knob were a bit worn out and couldnt screw properly. so took it back 2 brothers and after going through 2 or 3 knobs, 1 was not too bad. i decided to ask them to install it 4 me. the guy did it and it was alright, but if try...
