blacktop check engine blinking.
kampret
96
1,508
Hi sifu,master friends and all toyota lovers, i need help...when i start my engine without air-con the check engine light will not blink but i will blink when i use the air-con.i stay at balakong..if anyone have a master mechanic for toyota please give me his details.
Thank you.
kampret
96
1,508
bro...help me please...if that is a big problem,i ll need to take note about that...but i didnt know what happen?some of my friend say wiring,some of them say trotthle body..pls give a a advice or any suggestion?
levin818
1,260
321
3,183
Shah Alam
Hi Kampret
It won't be trrottle body problem... go kick your friend's ass for the fault advice :biggrin:
Did your aircon still running cool?
How does this problem happen? After service your aircon?
pyan14
engine check normally due to the fault sensor. there are several sensor on your car. try to check with your car workshop.
kampret
96
1,508
Thank for the info bro and sifu...actually my aircond still running in good condition.is that problem related to my aircond?i have never service my aircond after change my engine.so do i need to go to the workshop to check my computer box or i need change something related to this problem?anyway thanks for your support..i appreciated that.
chinozie
Very Young Member... :D
3,429
170
5,163
Damansara
4age20v.blogsome.com
Hi there...
when you turn on the air con...did the RPM went below then 800 rpm and shoot up again back to normal...?
kampret
96
1,508
when i drive...it will happen suddenly if i used the aircond...and the rpm become 500..and it will be normal again if i turn off the aircond.it happen to you before?
levin818
1,260
321
3,183
Shah Alam
Try retrieve the error code from the ECU.
If there is no code then please check what type of the ECU you are using (5sp - grey socket, 6sp - white socket).
If it is grey socket then most likely its the ECU problem.
levin818
1,260
321
3,183
Shah Alam
Wong...not because of dirty TB aaaa ? clogged vacuum holes...
Yes a clog TB will cause the idling to drop to 500rpm when turning on the A/C
But it will not cause the check engine light to blink.
So far i can only link the blinking check engine light to ECU problem.
It mean, his car may have more than one problem...
kampret
96
1,508
Hye sifu and friends
ermmm....if you say like that, thats mean i need to change the ECU?or it related to wiring?my car got many problem?ermm...i need to send to workshop?
but for this 3 days i used my car....the check engine stop blinking.why?? i cant understand...it make me crazy:confused:.Last Monday i drived my car to Klang but its running smooth...but i afraid it just for a while and i afraid to used the car for long journey.
Bye the way thanks for your support and advice.
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
diagnose it so u can easily know which sensor is giving problem
so u can check the sensor itself, harness,connector, wiring etc.
if sometimes ON sometimes OFF, clean everything and plug it back then reset ecu.
if OFF permanent then solved, if still ON and wiring evetything is fine. sensor itself need replacement
I`m using 15" rims for front and 16" for rear, any bad effect to my car? My old rims crack 1 piece so I buy 2 piece from hafkat shop.
15" (front) 15/7j/offset 43 tyre 195/55
16" (rear) 16/7j/offset 44 tyre 195/45
Plss ... need to know very urgent.
