b16a turbo engine vibrate
seek88destroy
65
hey , i jz mod my b16a wif turbo...but after i drive a while sometimes i can feel like the engine vibrate...so wats the problem wif that..i check the mounting ..all okay...so...any advice..:confused:
pinecitygarage
61
24
1,508
SoCal & Baguio
baguioautoforums.com
There are a lot of possibilities for the Vibration:
1. base idle and timing need to be set properly
2. your Engine Mounts are too soft and at hard acceleration or high rev take-offs your engine torque's front to back, causing wheel hop due to the engine moving, the tranny moves and your axles with it causing wheel hop
3. you need to check for broken stabilizer links, bushings and balljoints, the axle might also be bent. also check your struts (they might've blown)
4. check your wheel balancing as wheel, if you notice vibration only at high speed.
Tevs
yesterday my car kena scratch by i think a lorry .... a lil out of shapr oledi .... out of shape nvm .... but leave one line like half inch thick and 1 feet long without paint wah so clear ..... can anyone tell me how to recover that line without spraying the whole door .... coz expensive la .... i just wan the line to dissapear onli ..... any idea ?
