coolbuddy 3,000 RPM Senior Member Apr 30, 2007 3,376 3 1,638 May 5, 2007 #1 hello to all daihatsu owners...help me!!! what offset can fit to aura??? max-min thanks.....
- D i a b l o - 500 RPM Senior Member Sep 27, 2005 696 30 1,528 Shah Alam bosstrain.blogspot.com May 5, 2007 #2 i think max is 42 for g100
O onyx Known Member Senior Member Mar 8, 2005 301 0 3,016 May 7, 2007 #4 yeahhhh corect min must be - 38!!! if not kena ketuk body!!!!
Maxx 2,000 RPM Senior Member Feb 17, 2005 2,072 42 5,148 PD-Putrajaya-KL www.zerotohundred.com May 7, 2007 #5 depends on rim size also, especially width. if 15"x6.5". 38-40 will be the best. some fender rolling might be needed. 14" maybe no problem.
B brutus Known Member Senior Member Feb 7, 2005 87 0 3,006 May 29, 2007 #6 i hv a set of 6x14 et35 wit 175/65 oso need 2 kutuk d rear mudguard a bit. i tot avoiding 185/60 wud solve d problem.
teztozterone Known Member Senior Member May 18, 2006 381 0 1,516 May 29, 2007 #7 max i think is 45 la dudes 14" deto mah...lol
Maxx 2,000 RPM Senior Member Feb 17, 2005 2,072 42 5,148 PD-Putrajaya-KL www.zerotohundred.com May 29, 2007 #8 brutus said: i hv a set of 6x14 et35 wit 175/65 oso need 2 kutuk d rear mudguard a bit. i tot avoiding 185/60 wud solve d problem. Click to expand... urs offset to much, 35mm. so need to ketuk/roll the fender. lower offset number more "terkeluar" the rim and tyres. higher more "ke dalam".
S spsmotosport 500 RPM Senior Member Oct 18, 2005 788 0 1,516 May 31, 2007 #9 to kawansejuk... i'm using 15 x 6.5" with max offset 42... i've used 14 x 6" with min offset 38.. Last edited: May 31, 2007
