ATF. Stick to stock or use hifi I.E Torco?
sanekit
Dec 9, 2015
1,616
157
663
My take is slightly different from everyone here. Even if your car is stock, what is the purpose you want to change to a higher performance oil?
Back when I still had an auto Wira, before I installed a ATF cooler I was on the stock Proton SPIII oil. I used to go Genting a lot and would use gear 2 and 1 a lot downhill. There was one time I managed to overcook the gearoil and once I reached the base of the hill and shifted to "D" it wouldn't go to the overdrive gear and stayed in 2. I stopped by the side of the road to let it cool down for about 15-20 minutes. It started shifting normally after cooling down, after that swapped out the ATF to Diaqueen SPIII. Never had the overheating GB problem after the switch. I personally think better ATF has better heat resistance (viscosity should be the same) and has higher tolerance to take a beating.
If you're just driving casually in town and don't really drag your gears much you don't really need high performance oil especially if there's nothing wrong with your GB. As long as you using original correct spec oil you're fine for everyday puttering around.
hence i said if TS does spiritual whacking, he can change to performance one. hehe
6UE5t
6,000 RPM
6,756
1,300
That happened to me too but when my oil was getting old or like last time got leak, hence less volume and easier to overheat.
Darth Evillus
69
4
8
33
What about oil filter? Using performance filter and stock filter any diff?
Some people go the extra mile
ATF flush
Engine flush
ixeo
4,788
3,080
KL, Malaysia
ATF flush
Engine flush
Use original factory oil filter..good enough. Problem with aftermarket. You don't really know if its quality or they just slap their brand on some made in China filter...
:wavey:Hi all hope u guys enjoyed this post
erm due to zth auto resize pictures im afraid you cant view the pics of words properly, here in the direct link to the post
http://i.pictr.com/y2fsbni18f.jpg
