is it apline speed racing at sunway...
the ceramic coating is good stuff, reduce bornet heat by 50% and retain heat inside the exhaust pipe... increase 2 to 3 hp.... we also provide same coating,
my 1 is double layer coating.
unless use air pump suck the radiator heat from side and release the radiator heat to the side mudguard. then ! would said true 50% reduce under bornet temp[...
not much help , i vented my bornet with Evo3 scope 2. it just look nice but really does not help much, the heat come from turbo exh and fan. the only way is did what i suggest b4...
yes.. almost 0 friction, also can coat on the cylinder block wall..
conrod&crankshaft bearing, caliber piston, valve guide, valve spring, valve, intake port and exh port,,, all part can coat... with diff coating.
guys, any1 here have the experience in upgrading their wira suspension?
i mean from 1.3 to 1.6 suspension... as i know, the 1.6 absober n spring is bigger in diameter. so is the top mount different? i mean the black cover to coordinat the spring n to screw at the top. i ask a few forman n some suspension sellers, some said need to change. but some of them nvr mention abt that thing at all, say just buy the 1.6 spring n absober will do.
any1 could help me?
