APEXi Auto Timer settings for 4AGE 20V
et_box
501
13
Hi,
Does anybody know what is the optimum / correct setting for the A/F & O2 function?
Also, how would i know if my O2 sensor is still working?
Would appreciate any comments.. thanks!!!
tom's
2,865
76
subang
www.zerotohundred.com
on 02 my reading during idling is around 14+,,,,,,,,
a/f jump around alot from 0.2-.8+
if ur 02 koyak, no reading at all or the reading takes very long time to read, n
the af will jump at very small gap
et_box
501
13
Then my O2 sensor must be out... keep getting blinking red and green lights when i select the a/f & o2 function...
WrX7
266
check ur engine dianogsis, this happened to me once..its not the O2 sensor that spoilt but the ecu itself...
no more error code once new ecu plugged..
wish u luck...
tom's
2,865
76
subang
check ur wiring of the pen timer too......for blktop.....u need to connect the timer ground to ecu ground......do not ground it to any part of the body...silvertop if diffrent....last time my 20v blktop 02 koyak no error code.....
20v trompet
2,024
Aichi, Japan
Actually I have a problem to, I already install da APEXi auto timer...
the problem that i face is when I on my timer, in less then 1 week times...
my engine felt really heavy, n knocking some more... after I off da timer everything is ok n back to normal...
et_box
501
13
wish u luck...
WHat's the reading i should get using a multimeter?
et_box
501
13
Hi bro, i'm using a silvertop... how should it be grounded then?
Stretching the meaning of the word ‘used’ to its most technical limits, Japanese used car auctioneer Aucnet has sold a barely-driven GT-R at auction. The pearl-white Premium Edition GT-R sold for 10.4 million Japanese yen (USD=JY111) on December 10th, which works out to roughly US$94,000 or €63,945 - about US$25,000 over the base MSRP of $69,850.
Although the GT-R’s mileage is unknown, mileage was probably close to 0...
