Aircon - Warm after long run?
OTF-39
288
Hi all,
I have a question here regarding car aircon.
What is most likely the root cause if the air con of a car become warm after a long run ? (eg, after driving it for 2 hours at highway)
Whenever the car is start, air con was cold and okay.
Thanks
mag9556
2,770
43
1,648
better send it to car air cond specialist for this...
might be your aircond valve got problem..
normally it wont like that...
OTF-39
288
what does the valves of an air con do?
zan
2,154
the problem is call icing up.
you see, when we demand maximum cooling power, after some time there will be ice build up at the evaporator @ cooling coil. the problem is, compressor does not cut off even though its already cold.
check entire aircond system. clean cooling coil if dirty because dust deposit makes it easier to become ice and block blown air from the blower.
temporary measure to counter the prob - after half hour (or when cabin is cool), reduce the themostat bit by bit until the you are most comfortable. if icing up still occurs, switch off air cond. let blower runs alone and it will melt the ice.
this problem happened to my 20 yrs old mitsubishi super touring several years back.
mag9556
2,770
43
1,648
Izit true tat by 2010 there will be no R-12 gas and only R-134a gas? Then wat to do with older model car air conds?
Actually its not 2010 but 2009.. there will be no R-12 gas anymore...
lod system can use new gas just need to make sure dun overload...:biggrin:
mag9556
2,770
43
1,648
nothing much, market just like 'dead fish'....hahaha...:biggrin:
Dead fish? still ok what better than salted fish...hehehehehe....
once aircond kong.. really dead fish smell inside the car...yek...:slug:
I got some question here...
how to install charade detomaso's brake system on a charade aura...?
imagine this...
you use daihatsu charade detomaso's brake knuckle to put on a daihatsu charade aura...the problem is the lower arm...the aura one has similar to kancil's lower arm...but the detomaso's one not...
the deto's lower arm cannot put in the aura...the head (bull joint...i think...the one that have rubber and can move) are not the same...and the physical look also not...
