aircon blower thinggy removel
whatdamn
1,344
Cheras, KL, Mal
how do you remove the aircon blower? must i remove the entire dashboard? coz there's a dried leaf inside lar..can't 'kiap' it out with tweezers...afraid it might break.
thanks in advance,
oh proton putra by the way....
TypicalGuy
1,111
thanks in advance,
use vacuum cleaner to suck then kiap..
if break into peaces..at least still can suck mah
whatdamn
1,344
Cheras, KL, Mal
yeah thought of that, but was thinking i could learn how to remove those aircon ducts so i can vacuum the ducts itself.
stargate
105
Better don't try to remove the aircond ducts, coz the plastic is very fragile and you may scratch your dashboard accidentally.
CressTT
39
thanks in advance,
the blower can be removed easily if you know which bolt to be undo under the dahsboard....its just left to the cooling coil setup...just remove any bolt that hold the blower mooter container and for the hidden bolts/screw right at the back ..you have to somehow feel the bolt using your hands first ..its not that hard..would be difficult the 1st time and it'd be a breeze the second time...
good luck
TypicalGuy
1,111
air cond thing dun play play ler..
even those air cond specialist need almost half day to remove my whole air cond.
anyone experience using 4 throttle at vtec b16-b20?how does it feel?i'm modding it at my friend car using toyota 4 throttle.....:smokin::smokin:
