(Air tank) Can this things help us to improve our braking system to 20% - 30% ?????
SkYwAlKeR
10,146
300
ePoh ~ malacca
Re: (Air tank) Can this things help us to improve our braking system to 20% - 30% ???
u wan better braking power change to twin servo brake pump la... apa air tank pulak??...
Vagabond
1,730
53
Any idea where I can find a twin servo brake pump for a DC5 ?
Douglas575
Beyond 20,000 RPM!
20,932
5
Lol....i know also if can then i direct change car tats better ...hahhaa
but can u guys give some opinion on this air tank ? we talk this issues la...cuz if i got money i also change car alede.no nit use wut port wut port //.haha
ftzone
full throttle zone
5,339
141
Penang, Prai
www.ftzoneracing.com
I believe it's just cosmetics... no real performance gained.. unless the fabricator of this tank has solid facts and proof it works.
If me, I'd save some money to upgrade the braking system step by step if budget is limited. Such as steel braided brake hose, better brake pads and rotors. If budget allows, a better caliper is the best option.
davidv00
952
7
Selangor
use double DIN brake pump RM200 kaodim.... braking improvement is 60%
BLaCkHoWLiNG
'(^^)|Most Awesome Member
8,650
1,349
www.autojunctions.com
not to mention ... once u improve yr servo pumps, make sure u check yr brake lining first.. else it'll burst coz of the increased pressure... best to get steel braided
Esky
155
This tank will increase the vacuum reservoir. Some hv found it to improve braking a bit. Others install it on the PCV valve hose and find improved throttle response.
Make sure all the hoses are secured well if installed on the brake vacuum hose, as u don't want it to be leaking or coming off and getting no vacuum assistance when braking!
SkYwAlKeR
10,146
300
ePoh ~ malacca
How much is the twin servo brake pump ?
depends on what car u driving la... for example, wira can take evo twin layer servo... iswara can take vr4 twin layer servo...
GT_AUTO
3,501
71
K.Trg
www.facebook.com
this air tank has been around since the late 90's.i'm not sure whether it really
improve ur brake or not but some of the user claim it works.at first i thought
it increase ur air volume like having a twin brake servo.
Douglas575
Beyond 20,000 RPM!
20,932
5
Ya ... my frenx also installed this ... they sed improve in brakingla.... somemore they using bigger rims ...17" on wira....they sed really helps alots..
ken12292703
Drives a shopping cart...
1,542
5,138
SoMeWhErE
Hi bro,
The vacuum helps pulling the diaphragm inside the servo maa, right? The cross section area of diaphragm that counts lo. What does an external tank do? :hmmmm:
If increase volume with tank means it needs more time to get the hoses vacuumed for assistance hence more sluggish. :hmmmm:
Correct me is i am wrong. :love:
Maxx
2,072
42
PD-Putrajaya-KL
www.zerotohundred.com
purpose of the pump to increase vacuum capacity.
so when brake applied frequently in short time, theres still much more vacuum assist to the servo.
its like vacuum storage.
but this is just theory. donno help or not.
check valve/1way valve need to be install between manifold n the tank. (usually use the stock one)
btw, my h.cut did came with the "tank". not installing it yet when converting. no place to mount it nicely.. heheh
ken12292703
1,542
5,138
SoMeWhErE
Pressure = Force/Area
Pressure from vacuum is constant/same
Area of the diaphragm is constant/same
Then Force would be the same to assist the braking
The tank will increase the vacuum pressure? :hmmmm:
No offence bro, just curious~
GT_AUTO
3,501
71
K.Trg
www.facebook.com
does anybody here got pic of a cut out servo pic?at least we can study it
together.....hehehe...:)
SkYwAlKeR
10,146
300
ePoh ~ malacca
jeng jeng jeng...
tofu_manic
1,342
91
jeng3 but cant see pic le hehe :P
Ferrari unveiled their latest speed freak of a creation during the 2012 Geneva Motor Show, only to reveal a freak of nature in terms of horsepower: all 740bhp from under the hood of a V12 monstrosity that will catapult the car from 0-100kmh in just 3.1s!
<!--more--> Apparently...
