Air flow sensor - 1.8 4g93 n/a
satria81
813
18
5,018
PETALING JAYA
Hi All,
Please can I know on which would be the best air flow sensor code to be used for 1.8 4g93 NA.
I am wanting to have strong air suction sound during acceleration..
Thanks upfront for sharing
Hi All,
use stock air flow sensor la....
want air suction soun..just use open pod filter enough already
satria81
813
18
5,018
PETALING JAYA
hi Pomen GTR,
Thank you for the reply.
I am wanting the sound without dropping in an open pod.
I've heard that strong air suction sound from my frens putra 1997 model about 8 years ago without open pod but with stock air filter box. it is - great ( !! )
so was thinking to achieve the same via the correct air flow sensor
The closest will be K & N filter but not as good as open pot.....
hi Pomen GTR,
well..alternative is u have to use the drop in performance air filter...
AND
remove the airbox snorkle...
*the intake pipe before airbox and sensor
*the left pipe in picture
Maybe can mod and take out the whole incoming half. Just mount filter to second half.....:biggrin:
i did the flex CAI mod...
and then hacking up the resonator chamber of the stock airbox....not that grunty sound like full open pod...but more roar than stock airbox.. :biggrin::biggrin::biggrin:
satria81
813
18
5,018
PETALING JAYA
my frens putra had the strong roar sound with stock air filter box and hoses..even the throttle body was stock.
the air suction sound was so damn strong when the engine is revved up to 7500 rpm on 3rd gear - 170 kmh
the engine does not cry in totality when revved hard and the roaring sound is great !
it was on stock exhaust front to back
Stock everything is covered so you will need max rpm to hear the suction...:banghead:
I've already posted this question over at other automotive forums, so i hope it's ok to post here.
How do you actually determine that the clutch needs replacing?
If you depress the clutch pedal and it feels hard (needs more effort than
usual to depress), does it mean it needs replacing? A mechanic told me that
I need to replace it soonest.
Is he telling the truth?
Another thing I noticed is that almost all the time when I change gear, the moment when I press the accelerator...
