air con coming out from unwanted places
silverwave
141
My satria has this problem especially when it rains. the lower part of the front glass will be covered with mist because the air con is still on in that part. My control for the air con is spoil, therefore i cannot adjust it. is there anything that can be done to repair this? last time i consulted a shop, and the shopkeeper recommended that he has to remove the whole dashboard to fix it. anyone knows whether this is a good idea and how much it will cost?
TiBuN
482
Penang / BM
Maybe you can try removing your blower, and check whether your external vent got leak or not, if yes maybe can try fully seal your external vent. (Once fully seal then later cannot open back d)
Have the similar problem last time, recently just fix it using the above method.
Redline_club
892
www.redline-club.com
u mean the outlet control left right up down???
sta
639
use sticky tape to cover the vents at the top of the dashboard
silverwave
141
i think the switch to open n close the vent is broken, that's y when i adjust it it does not stop
silverwave
141
what outlet is that? u know on top our dashboard there is a vent? normally it is used during rainy days to get the mist away.
the air con is coming out from there. i cannot stop it, so during rainy weather there is a mist layer on the lower part of the screen
silverwave
141
it is a good idea, but it will look messy. i thought of putting the non slip mat over that layer so that there is no mist on the glass.
silverwave
141
what cable? the one to control the air con?
silverwave
141
putra4767 said:
must be the hose came off that area...
might be possible coz the air con is coming out from the right side only. left side is fine
silverwave
141
nitrus said:
u play alot with the control adjusting thingy last time eh? :biggrin:
nope, but actually all this only started after my car accident last year.
Does anybody know when its time to rebuild your manual transmission ? is there a "time" when you know you have to do it?
